Watched my R34 drive off into the sunset just now - new owner lives in Whyalla so won't be seeing her around ;)
Want a box of Kleenex there champ? :D Hope its gone to a good home.
Now STFU and enjoy the 350GT :cool:
I love the rear look of the 350GT, but love the front of the 350Z better than the GT. Can I have both? :)
anyone know how to remove a kenwood cd deck from a VT? do i need those special key things to remove the deck from the little sleeve thing?
from memory with my mates ss, 99% sure you do need that key thing Age
Park it in Lidabeff for a short time and it'll be removed for you. :domokun:
hahaha.. on that note,
if anyone is bored and has sore eyes... have a look at this.. will make your eyes better..
one thing ns.com is good for!! http://www.nissansilvia.com/forums/index.p...330611&st=0
lol anyone hear on nova last night they were testing how long it would take to get a pos car stolen at victoria square with the keys left in it.
annouced on over the radio to come and take it :domokun: was tempted to go down there n take it for a spin, get a speeding fine see how they like it.
i wanna grab some plastic ducting for a cold air intake, same as Krishy's and similar to Luke's front brake ducts. where can i get it from? Bunnings West Lakes had nothing!
Head down to my old work Damo, pretty sure they'll have what your after. Something like TPR Duct hose or similar is what you need.
thanks abe.. the guys at motoquipe west lakes hooked my up with a key and bam its out!
Ah yeah, sure no problem....umm whats the thanks for? :D
I think you meant this guy
Watched my R34 drive off into the sunset just now - new owner lives in Whyalla so won't be seeing her around :D
i spotted it in town at 2:30ish this arvo :D
was about to wave but seen a p-plate in the window so twigged that ya might hav sold it
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
