Watched my R34 drive off into the sunset just now - new owner lives in Whyalla so won't be seeing her around ;)
Want a box of Kleenex there champ? :D Hope its gone to a good home.
Now STFU and enjoy the 350GT :cool:
I love the rear look of the 350GT, but love the front of the 350Z better than the GT. Can I have both? :)
anyone know how to remove a kenwood cd deck from a VT? do i need those special key things to remove the deck from the little sleeve thing?
from memory with my mates ss, 99% sure you do need that key thing Age
Park it in Lidabeff for a short time and it'll be removed for you. :domokun:
hahaha.. on that note,
if anyone is bored and has sore eyes... have a look at this.. will make your eyes better..
one thing ns.com is good for!! http://www.nissansilvia.com/forums/index.p...330611&st=0
lol anyone hear on nova last night they were testing how long it would take to get a pos car stolen at victoria square with the keys left in it.
annouced on over the radio to come and take it :domokun: was tempted to go down there n take it for a spin, get a speeding fine see how they like it.
i wanna grab some plastic ducting for a cold air intake, same as Krishy's and similar to Luke's front brake ducts. where can i get it from? Bunnings West Lakes had nothing!
Head down to my old work Damo, pretty sure they'll have what your after. Something like TPR Duct hose or similar is what you need.
thanks abe.. the guys at motoquipe west lakes hooked my up with a key and bam its out!
Ah yeah, sure no problem....umm whats the thanks for? :D
I think you meant this guy
Watched my R34 drive off into the sunset just now - new owner lives in Whyalla so won't be seeing her around :D
i spotted it in town at 2:30ish this arvo :D
was about to wave but seen a p-plate in the window so twigged that ya might hav sold it
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
