It doesn't matter how fast it is, you'll still feel like you are driving a park bench. Magna's driving position sucks
you do know that there are levers and stuff that let you adjust the seat (both the angle of the back rest and the lower half of the seat.....
people always say 'i did it to be different' 'no one has done it' etc.. the reason no ones done it because its so fkn retarded
bahaha... quite quotable
Pull that engine out and fit it in an AWD Manual model and it may be a different story.... :P
STILL WILL UNDERSTEER LIKE A CIVIC
RPW are so good at what they do that their achievements are even discussed on a high and mighty Skyline forum.... :|
How many of you posting have run an 11.9?
Didn't think so...
But Spirro works on his Torri from the back of his fish and chip shop and can run an 11.8, but I'm not impressed. You can run any time in any car if you throw enough money at it.
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
