  • Replies 139
If you're an SAU:NSW member then sure :( There's plenty of spaces left :wave:
Otherwise, no... for some reason, it's members only...
Easy answer....
To encourage people to join the club,
to make current members stay and be involved,
and supporting the club for future events as thats one of the benefits for being a member, only doing member only days.
And there will certainly be alot more member days only coming up :P
Still can't find it in the events section, can someone point me to the link please.
There's been quite a few threads over the years that drag on about wanting to go go-karting and never get organised, so very keen for a day like this!
Thanks.
Ok, i think it's all just clicked in place for me now. You mean there's a hidden members section? You mean these past years I've been on here there's been a hidden events section that I didn't know about? Kinda pissed off now.
Ok just transferred the fee and faxing the form soon.
Guys, if you are trying to encourage memberships, it makes sense to show people what they are missing out on. People won't pay for something when they don't even know it is there. Might want to put it in the public events section as well as it sounds like a great event that makes people like me finally get off their arse and sign up.
I know, I know I should have signed up earlier, simply the information I have got from this board has been well worth the $60 membership fee. Thanks.
ps. can someone reserve me a spot please till my membership comes through. Cheers.
hehehe :w00t:
Yes, there IS a hidden members forum...
Yes, shit does happen in there...
Yes, it IS worth the $60...
When i signed up, I had no idea about it, i signed up so i can get discounts on other shit the club did... still money well spent if you ask me :)
For the record though, this go karting thing is the first members only thing since I signed up... So you haven't missed out on a lot... But there will most likely be more...
You gonna be there Richard??
We need to have some form of competition...... >_<
I hope so. I'm looking a bit shaky atm. car is half in pieces so I can install:
F+R R32 4.375:1 diffs
new tighter 2 way rear diff
sump baffles
turbos
manifolds
dumps
front pipes
replace tomei lock kit with lock bar
fit PS cooler
new injectors
new afms
new tune
steering rack bushes
new brakes
new engine mounts
new piping kit
new intercooler
new radiator
would like to squeeze a transfer case rebuild in amongst that lot too.
so I have a fair bit of shit to do, but hopefully it will be done in time. if not I might try and bludge a few laps of anyone foolish enough to let me drive their car. :P :PBJ:
Here's my list for entry:
Get rods in the mail, take them to workshop, come back a week later and pickup the finished motor, take motor and shell to different workshop, comeback week later, run in, tune, do a few dawn runs to make sure its all good, then thrash at EC
The times running out but im trying
my stuff which may cause me not to go...
1. fit injectors.
2. fit z32
3. retune car with powerFC to suit all new supporting mods
4. dot5 fluid
5. font brake pads
not as much as BB but not enough $$$ at the moment d'oh
sump baffles
turbos
manifolds
dumps
front pipes
fit PS cooler
new injectors
new afms
new tune
new brakes
new engine mounts
new piping kit
new intercooler
new radiator
so I have a fair bit of shit to do, but hopefully it will be done in time. if not I might try and bludge a few laps of anyone foolish enough to let me drive their car. :worship: :PBJ:
Fark me!!!!
Looks like your building a race car from scratch!!!!
Be good to see it in action, sounds like its gonna be a monster....
I like Hooters!! :laugh:
I can handle the hot wings too and Dave (T04GTR) cant :w00t:
I like hooters in general, but the hooters at Hooters were pretty ordinary, and the food was the same, at best...
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
