pretty sure they have to honour your lease even if they sell. once the lease is over they can boot you. or just make sure its a mess whenever you allow people to view the property, talk about the leaks etc etc
  • Replies 139
yeah.. chris, i wouldn't be too worried, they're probably buying an investment property! Ask the agent!!!
also draw cracks on the walls!
Anna,
Will let you know thursday also :rolleyes:
man,
just had the realestate agent over, they took photos n shit as its going on the market. farkin. we just signed a 6 month lease with view to 12, i was hoping to be here for 12!!
DAMMIT shit
oh, and place was a complete mess hahahahaha
Wow that was fast!
Buy the place :dry:
they are?
where?
hahaha yeah Im gonna mess the f**ker up, in the master bedroom I'll leave out some handcuffs, baby oil, a cat of nine tails and leave it there for the open house :yes:
lol steve - I have actually put an offer in, its 20k less than what they want...but we'll see :(
Anyone else from here going out on friday?
Oh noooooo :D
Thats so crap Bunts!!!
Was looking forward to catching up with you guys and finally get to see the car!!!
Oh well will just have to make a trip up to see you at some stage!! :D
yeah it blows, have had two offers on the car now so looks like you will never see it! All things going to plan the car will be in Cairns by early December!
I do Brad, tell ya what, I'll use your GTR!!!! :thumbsup:
deal? haha
Mav is up?? hahah sweet !
Anna, hopefully picking it up friday sometime, still not 100% - exhaust is restrictive, need a hiflow cat now! d'oh
Awww wow that was quick!!!
Can you at least send me pics of it so will get to see it that way..
I have work email now also will pm you :glare:
Are the vics going out after EC before they go back home??? A dinner or anything been organised......
Wont be making it to Wakie today..had to work after all :)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
