I personally believe that Boostworx's sweet spot is with the RB25. I believe there are other (most likely more expensive) workshops that have more experience with the RB26. I'm having my engine rebuild done by Manta Racing but won't recommend them until the job is complete and I have the car back. Go to the different workshops yourself and speak to the people there to form you own opinion. The usual places mentioned are Boostworx, Graham West, Manta, Tilbrook, Blackwood Dynotune etc. If you do a search you'll see this topic gets covered quite regularly.
https://www.sau.com.au/forums/topic/189713-tuning-shops/#findComment-3418147
^ David you will be happy with the work by steve cramp at Manta... he is very good.
As for tuning power fc etc I know shaun is good at boostworx, but I cannot speak highly enough of John Keen at Southern Hi tech.
https://www.sau.com.au/forums/topic/189713-tuning-shops/#findComment-3421227
One of the most switched on poeple i and my family have had experience with lately is Steve Bell at Bell's Auto's on main north road. His experience is varied but his undestanding of the workings of the internal combustion engine and every aspect that affects its function is amazing. I believe Martin has had experience with Steve also.
https://www.sau.com.au/forums/topic/189713-tuning-shops/#findComment-3421445
Thanks Martin. I have no complaints about Steve or Manta except their hourly rate of $91.30... and that the car still isn't ready (although that's not actually Steve's fault). The engine blew on May 12 and was at Willall within a week. Five months later and I'm still waiting. And the cost... OMG!!!
https://www.sau.com.au/forums/topic/189713-tuning-shops/#findComment-3422118
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
