before you pay $790 for that set get a price for Hankook Ventus K104... same price awesome tyre, far superior to Nankang without doubt cant comment with Fedral never tried them. The Ventus K104 is the shitz ..... 235/40/17 for $190 each and Im using R34GTT mags
edit: ahh 18's my bad. hhmm price the K104's anyway =D
I've got 595 0n 17's. Wear is OK. 33k at present, on the rears. Got about another 5k . Cant tell about the fronts, as a dodgy tie rod end scrubbed them
out.
I find them a bit noisy though.
K104's FTW!
I put K104's on my car and while I haven't had any traction issues I find the fronts are a bit funny with off centre feel. Maybe I was just spoiled with the Dunlop Formula W10's that were on my car when I bought it... they were clearly a few years old and but it felt like the front end was glued to the road. F*ck they were noisy though.
had federals on my stagea when i got it and they were lucky to last 30,000klms. they are crap and if you really want a decent tyre go for michelin all the way.
i switched and man what a difference in ride, so much smoother and quiet to boot!!!
just my 2 cents
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
