hi, i'm new to this forum.
recently i replaced the blown engine out of my r33 gtst skyline with another one that i bought off ebay. everything went in and it starts and everything. however, there it has a few problems.
1) the revs fluctuate betweeekn 500 and 1300 rpm.
2) when driving and coming to a complete stop when you have the clutch in it just wants to stall out.
3)there is this fkn loud tapping sound comming from the bottom of the inlet side of the head. ( a few people have told me that it could be the lifters) personally i think the person who put the timing belt on originally it could be a tooth out but would it cause this problem? and the car goes really shit not smooth at all!!!!!!!
4) when coming on boost, the car just backs off by itself liek it sputters and missfires.
ive nearly had enuf of this car lol.. plz help. Thanks in advance
https://www.sau.com.au/forums/topic/190213-tapping-sound-coming-from-engine/
1. Check AAC Value - also related to #2
2. I reckon you have a vac leak in a hose somewhere. Go over them all and find it
3. Could be anything fron noisy injectors, to lifters. Get a mech to check if unsure
4. AFM or, again the vac leak causing issues, spark plugs possibly, coils... could be many things
Basically you have common problems that are all trial and error mate.
Just keep checking parts, and have a read of various 'misfire' threads in this section that go over various problems.
AFM for the idle problem, stalling might be caused by a incorrectly place hose or not sealed like a atmo blow off valve. Also sure its not doing R and R rich and retard. The ticking most likely bad seated exhaust manifold, Check intercooler pipes and what not.
i mean liek a really loud tapping sound at idle.. and this gets louder the more u rev... it sounds like the cam is hitting the lifters
Sounds like big end bearings to me ..... Is it louder when the engine is hot ???
Im pretty sure that if it was a spun bearing the engine would be dead by now as once they go, they don't last much longer so i don't think its that.
If it gets louder with revs its obviously something that rotates and increases in speed so check your timing belt, tensioner, cam gears etc. If not then yeah it could have something to do with your cams/lifters.
Hi,
I've got the same problem with loud tapping sound on my R34 GTT except that it isn't always there, it's intermittent. I suspect VVT as it's comming from around the same area where VVT is situated on the intake cam. I know that SR20 from S14 and S15 are notorious for noisy VVT so I suspect that RB might have the same problem.
It'd be interesting to know what your mech's verdict would be.
i had that for a day or 2, turned out to be my radiator fan hitting the intercooler piping :P
Haha, I had the same problem. I removed the insulation from under the bonnet and problem solved. Seems the bonnet+insulation was pushing down on the i/cooler piping and as a result the fan was hitting it. :P
  • 1 month later...
This may be a few things.. but i think its the oil not getting up the top of engine quick enough? What viscosity oil are you using?
not sure wat oil, i put synthetic oil that was recommended from autobarn
they looked up my car in a book?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
