I have 9k to spend on my car 2k is going to body work the other 7k is for performance.
Any ideas what to do?
My end goal is about 350rwkw this round of mods id be happy with 260-280rwkw
I though of putting in an rb25 new afm injectors coilpack bigger turbo all running from my rb20 ecu.
Next round of mods would be forged bottom end.
How does that sound or is there abetter way to go?
https://www.sau.com.au/forums/topic/190840-best-way-to-spend-7k/
Unless of course you do it all yourself.
RB25DET
+HKS gt-rs or 3076R on standard manifold. $2400
HKS Exhaust or equivilant. 3" $1200
decent frontmount kit. $600
Engine management $1500
nismo 555cc Injectors $870
z32 AFM $450
Splitfire Coilpacks $525
Decent Fuel Pump $300
total So far $7320 + tune $500.
You could save yourself some money using a Garett Huffer which is only about $1600
so that brings it down to $7520
So you can add a Oil cooler $400. Plus new oil $60.
New total :
$6990.
These Estimate of course are very rough. But that brings you quite close to your immediate goal. There are many different routes you could take. You could however, start off with a strong build, that way you will be ready for your go fast bits to get up to your 350rwkw goal. And in doing anyjob like this You will be suprised how many other little things you will have to get that you didnt think of even when doing it yourself.
If you got 7k to spend, budget 6 for parts. and 1k for the unexpected which will happen.
You will also need a decent clutch.
If you want transplant go RB26.
for about $4.5-$5K you can get
used RB26 complete with turbos, AFMs, intake gear, injectors, intercooler etc etc.
get the sump modified and fit it up.
run 1 bar boost and whack in a power FC then you have 250-270rwkw all day long. it will probably stretch your budget a bit and you will need a few other things like fuel pump etc but it will be pretty cool.
Why go rb26 when you can go a much cheaper alternative of a 25/30 and then spend the rest on a turbo, management and injectors?
Also, there is a guy over in tassie with a tuff little rb20 already setup thats not in the car yet, td06, management, injectors, HKS cams etc... maby ask him if his interested in a swap + cash or something. After seeing Roys results with an rb20 running a similar setup (minus cams) I wouldn't be surprised to see it kick out some very decent power.
Rb26s are overpriced in my opinion, they do offer a few advantages (cams, plenum, lifters to mention a few) but the way I look at it, a hybrid costs less, make alot more midrange and with is ability to spool a the huffer sooner, will make a much more street able car.
Or you could go to the casino, double your money and drop in a 2jz or even an ls1. Do it, I dare ya!!! hahaha
yeah a + 1 for a 25/30 hybrid also... bigger bang for your buck! Find a good cond stock bottom end that is known to be healthy, get a head, some GTR cams and regrind them larger (PM cubes for this) then with standard manifold run a GT3076 with the larger ex housing, IW and grab an RB20 ecu, rechip that (you'll be ditching the VCT anyway) and you'll make an easy 300 + rwkw reliably, keep the revs below 7000 and it should last a long time.
motor $100-200 (for a s2-3 RB30 in good cond, only need bottom end)
head $900-1000
cams + regrind $500
RB20 ecu $100
remap and tune $500
turbo + lines and dump $2.2K
still got plenty money left to play with
head $900-1000
cams + regrind $500
RB20 ecu $100
remap and tune $500
Hmm I could be wrong but there seems to be a few things missing here..
he has
currently rb20det with FMIC pod filter TBE r34gtt turbo. Apexi AVCR boost controller.
Before the turbo was put on it was making 195rwhp. Going in for retune of stock ecu hopefully this weekend
you don't seem to have any:
gasket kit - $250
valve springs - $500
Machine shop work for head and block deck for a perfect seal and to tap the nw timing belt pulley - $300?
New water pump, idler and pulleys - $300
new timing belt - $150
injectors - $500
fuel pump - $300
Z32 AFM - $300
clutch - $700
run in oil, new oil, oil filter, new coolant etc - $150
other (covers things like new hoses, vacuum lines, bolts and nuts you break, little seals from the 20 year old bottom end that might be leaking etc) - $500
how's that budget 300rwkw coming along now?
I reckon stick with the original RB25 transplant, but plan to get the bottom end forged for over 260rwkw of power.
It's still gonna handle at least 300rwkw with the mods you want, and with some top end mods (cams/cam gears/v. springs/port&polish) will be able to make a lot of power.
So you'll save a bit on buying the 25 rather than a 26, and you're not going to be 'disadvantaged' that much with the end result.
Thats my 2c
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
