  • Replies 72
I doubt they would sell it to someone if they didn't actually own the new GTR and actually needed the engine to be replaced. I could just see some idiot doing this:
"Hello Nismo? I would like to purchase your new GTR engine so i can put it into my fully hektik VL turbo."
Click-Click, Beep Beep Beep.
"Hello u there? Hello???"
https://www.sau.com.au/forums/topic/191550-r35-engines/#findComment-3446247
lol
Thats the best part, fully sick vl owners wouldnt be able to afford it, if they could, they would be driving a newer model commodore :P
https://www.sau.com.au/forums/topic/191550-r35-engines/#findComment-3446658
The VR38DETT sounds like a beast...titanium used extensively so would cost a fortune.
Only thing i dont like is the 7000rpm redline...a GTR motor should rev past 8k im my opinion :P
...hopefully it does and the limiter can be removed.
They don't need any more revs to produce the power they want . Do you know what the 911 tt Porka's redline is ?? 6500 rpm and she goes like the clapers with plenty of torque at 2000 rpm . My guess is this is what Nissan are trying to copy and by the reports we are getting they have done a good job . I wonder if the R will have a dry sump, like the Porka, hold heaps of oil , like the Porkas ..
https://www.sau.com.au/forums/topic/191550-r35-engines/#findComment-3446751
lol
Thats the best part, fully sick vl owners wouldnt be able to afford it, if they could, they would be driving a newer model commodore ;)
:P Funny, couple of year ago I saw a VL on ebay with full GTR drivetrain, reserve of $50K. Laugh my arse off, it still looks like a VL and is just as comfortable on the inside. At the time I had a VL and other than the RB30E & gearbox, the quality of the car (esp. the interior) is poo.
https://www.sau.com.au/forums/topic/191550-r35-engines/#findComment-3446775
this is ridiculous
you think that any motors will be available for non-warranty related repairs inside the time frame of the factory warranty?
reckon you'll just be able to ring up and say "err, yeah, hi- look: the motor in my R35 blew up. pls send me a crate motor so i can install it myself"
unlikely
https://www.sau.com.au/forums/topic/191550-r35-engines/#findComment-3447228
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
