  • Replies 53
dang bad luck......gotta be careful around exam times man....i dont think i ever went in the skyline during exams unless i had good sleep (99% of the time, I was living on coffee)
sux2b the other guy too
but as the others said, main thing is no one was hurt
that audi isn't a write off.
the insurance coy may just give him a new one b/c it is so new...
but that car will end up at pickles or manheim fowles...
chassis doesn't look bent on the TT so it will be repairable.
Sorry to hear and main thing is you are OK. The damage to the Audi doesnt look that costly or like it could have affected it too badly structually. Is it worse than it looks?
At least you had 3rd party insurance too
yeah its worse then it looks in that pic.
anyway
good news
i had a mechanic/panel beater for the HRT v8 supercar team and he said what needs fixing
new radiator
air conditioning
airbags replaced
windscreen
all the front body work
and a bonnet
anyone recommend some good places in melbourne to do this work, preferably one that specialisez in imports and has easy access to parts?
edit: ps. i understand that people may not be able to recomend/slam business on a public forum. so maybey a quiet email/pm
[email protected]
i am looking at the sticky thread about workshops and parts and dealers and just hoping to be able to narrow down the list
Edited by finster
anyway
good news
new radiator
air conditioning
airbags replaced
windscreen
and a bonnet
[email protected]
Vu DT panels in springy.... import king
fark thats bad luck dude, hopefully u get it all sorted out, tough times
ye the last thing id want after buying a brand new Audi is for some1 to hit it then getting it back repaired, id want a new one too if ive forked out that much money.
Mate I know exactly where that is. When I was young and dumb i used to give that corner a little clutch dip every now and then on my way home from work. That was untill the cops and residents figured out what time I did it on certian nights and I got a serious warning. Im sure you wernt doing anything that silly. All the best with the repairs.
Ahhh so that was you... my mate told me about this on Saturday night, he saw the aftermath just after it happened.
You're a De La boy then?
yeah de la boy. there is still some bits of my grill at the scene :'(
thanks for all the tips. im gonna start doing some calling next week.
every time i decide its not worth it to get it fixed i have a look at it outside my house and change my mind
from looking at ur second shot, seams like the reo has been chopped, maybe in japan, if thats the case you'll have a tuff time getting insurance to pay you out. they'll claim that the cut out caused a laxk of structural strength and void ur insurance.
Looks like a standard series 2 reo to me. they are a bit thinner than the series 1's
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
