  • Replies 53
dang bad luck......gotta be careful around exam times man....i dont think i ever went in the skyline during exams unless i had good sleep (99% of the time, I was living on coffee)
sux2b the other guy too
but as the others said, main thing is no one was hurt
that audi isn't a write off.
the insurance coy may just give him a new one b/c it is so new...
but that car will end up at pickles or manheim fowles...
chassis doesn't look bent on the TT so it will be repairable.
Sorry to hear and main thing is you are OK. The damage to the Audi doesnt look that costly or like it could have affected it too badly structually. Is it worse than it looks?
At least you had 3rd party insurance too
yeah its worse then it looks in that pic.
anyway
good news
i had a mechanic/panel beater for the HRT v8 supercar team and he said what needs fixing
new radiator
air conditioning
airbags replaced
windscreen
all the front body work
and a bonnet
anyone recommend some good places in melbourne to do this work, preferably one that specialisez in imports and has easy access to parts?
edit: ps. i understand that people may not be able to recomend/slam business on a public forum. so maybey a quiet email/pm
[email protected]
i am looking at the sticky thread about workshops and parts and dealers and just hoping to be able to narrow down the list
Edited by finster
anyway
good news
new radiator
air conditioning
airbags replaced
windscreen
and a bonnet
[email protected]
Vu DT panels in springy.... import king
fark thats bad luck dude, hopefully u get it all sorted out, tough times
ye the last thing id want after buying a brand new Audi is for some1 to hit it then getting it back repaired, id want a new one too if ive forked out that much money.
Mate I know exactly where that is. When I was young and dumb i used to give that corner a little clutch dip every now and then on my way home from work. That was untill the cops and residents figured out what time I did it on certian nights and I got a serious warning. Im sure you wernt doing anything that silly. All the best with the repairs.
Ahhh so that was you... my mate told me about this on Saturday night, he saw the aftermath just after it happened.
You're a De La boy then?
yeah de la boy. there is still some bits of my grill at the scene :'(
thanks for all the tips. im gonna start doing some calling next week.
every time i decide its not worth it to get it fixed i have a look at it outside my house and change my mind
from looking at ur second shot, seams like the reo has been chopped, maybe in japan, if thats the case you'll have a tuff time getting insurance to pay you out. they'll claim that the cut out caused a laxk of structural strength and void ur insurance.
Looks like a standard series 2 reo to me. they are a bit thinner than the series 1's
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
