Saw some white GTST33 today, plates were leg41 or something.
im told that is a gts thats had an engine swap done,
i saw shane (47apn) come outta the gateway toll plaza headin north thisarve, bout 5:30 or so,
i also saw a maroon 33 headin towards the sunny coast on friday afternoon, had some horse training advertising sticker on the rear window, he seemed pretty happy to see me, waving madly ect
I saw a burgundy R33 with a Nismo decal across the bonnet on the corner of Rode and Gympie road, i waved, and got a weird look in reply...
I think i'm going to give up waving, all i ever get is weird looks :S
Might have been me. About what time was this?
What did the nismo decal sticker say?
finally someone spotted me lol... where were u mud? didnt see ur red beast anywhere in sight...
I was standin on the corner givin you the evil eye!
Had quite a few beers under the belt by then,
I didn't wave as I thought it might put me off balance and I'd fall over
Hey Dude, don't think it was u, would have been me as i jsut dropped a mate off at work, and i saw the other liner go past, but keep it up and keep spotting dude.
Later
Rob
Later
Rob
I didnt think it was going to be me. But I've been around on rode road area for the past few days visiting friends. But only at night.
I have been holidaying in brissy and toowoomba and up the sunny coast, I did a little over 6000 km's over the last month and I spotted a heap of skyliners, several with Sau stickers, so surely someone spotted me.
Black S1 r33 (see avatar for plate)
Edited by Sneeky
Saw about 10 skylines last night in town. a Black R33 with a GT wing, a yellow R33 GTST, grey R32 gtr, Yellow R34 GTT, White R33 4 door gtst and many others as I was drunk and cant rememeber number plates.
any of theses you guys?
Chris
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
