If it's the same one i'm thinking of, it has 20's and the front bar has been cut out big time.
Its got some kit on it. Didnt look too bad, but WAY too low, and WAY too big wheels, and its slow.
At Carindale, near the escalators down near Laura Asheley.. you were talking towards the post office
Oppps...sorry I'm sure I wasn't staring, just not tuned to watch out for skylines when inside a shopping center! :P
yea, saw it tonight. i only got a quick look, but i was amazed. i never thought id see a middle aged women driving a modded gtst r33. nothing wrong with it, just unusual.
cool.
yeah it's been around for a bit. good to see a few more ladies owning skylines.
spotted a white 4 door r32, i think u honked at me twice, was on anzac avenue redcliffe headng towards rothwell.
also on anzac avenue, a black r33, u showed off ya blow of vavle a few times :blink:
and finally, another black r33, u follwed me from anzac avenue, all the way to the sea front,.
YAY!
Can you get us cheap stuff!?
Yeah... Find it and ill do it as cheap as possible for ya....
Call 3834 1100 ask for Colin
Is that a Factory yellow Col?
No not factory its dulux base yellow, was painted 12 months ago now....
Makes it easy when i need to touch up bits....
Panel beater says: What colour is it...?
Col says: Yellow
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
