If it's the same one i'm thinking of, it has 20's and the front bar has been cut out big time.
Its got some kit on it. Didnt look too bad, but WAY too low, and WAY too big wheels, and its slow.
At Carindale, near the escalators down near Laura Asheley.. you were talking towards the post office
Oppps...sorry I'm sure I wasn't staring, just not tuned to watch out for skylines when inside a shopping center! :P
yea, saw it tonight. i only got a quick look, but i was amazed. i never thought id see a middle aged women driving a modded gtst r33. nothing wrong with it, just unusual.
cool.
yeah it's been around for a bit. good to see a few more ladies owning skylines.
spotted a white 4 door r32, i think u honked at me twice, was on anzac avenue redcliffe headng towards rothwell.
also on anzac avenue, a black r33, u showed off ya blow of vavle a few times :blink:
and finally, another black r33, u follwed me from anzac avenue, all the way to the sea front,.
YAY!
Can you get us cheap stuff!?
Yeah... Find it and ill do it as cheap as possible for ya....
Call 3834 1100 ask for Colin
Is that a Factory yellow Col?
No not factory its dulux base yellow, was painted 12 months ago now....
Makes it easy when i need to touch up bits....
Panel beater says: What colour is it...?
Col says: Yellow
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
