If it's the same one i'm thinking of, it has 20's and the front bar has been cut out big time.
Its got some kit on it. Didnt look too bad, but WAY too low, and WAY too big wheels, and its slow.
At Carindale, near the escalators down near Laura Asheley.. you were talking towards the post office
Oppps...sorry I'm sure I wasn't staring, just not tuned to watch out for skylines when inside a shopping center! :P
yea, saw it tonight. i only got a quick look, but i was amazed. i never thought id see a middle aged women driving a modded gtst r33. nothing wrong with it, just unusual.
cool.
yeah it's been around for a bit. good to see a few more ladies owning skylines.
spotted a white 4 door r32, i think u honked at me twice, was on anzac avenue redcliffe headng towards rothwell.
also on anzac avenue, a black r33, u showed off ya blow of vavle a few times :blink:
and finally, another black r33, u follwed me from anzac avenue, all the way to the sea front,.
YAY!
Can you get us cheap stuff!?
Yeah... Find it and ill do it as cheap as possible for ya....
Call 3834 1100 ask for Colin
Is that a Factory yellow Col?
No not factory its dulux base yellow, was painted 12 months ago now....
Makes it easy when i need to touch up bits....
Panel beater says: What colour is it...?
Col says: Yellow
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
