I spotted a bright yellow Vespa scooter with large black lettering both front and back which said "SKA"
His fans are everywhere........ sick freaks!!
Stop denying yourself, you know you love me! They all do.
i want nismo plates lol spotted WILLO 34 gtr and DIS15 s15 cruised along with both till city turnoff , also a few liners .. waved at a 4 door white sedan 33 dwn coast femaile driver instead i get a finger ! lol some ppl .. tsk tsk..
Yeah Erin, Andrea thinks I'm waisting my time waving madly at every Skyline I see, but I am determined to get more people involved in their cars if it kills me. A simple wave is not a lot to ask, is it???
Well recently got back from holidays up in your pretty state and saw a few skylines around the place. Maroon R32 GTR near Broadbeach last Wednesday, awesome looking R34 GT-T in the Pacific Fair carpark on Friday (number plates RIDE M3) and a maroon aus delivered R32 GTR heading towards Brisbane airport on Saturday afternoon.
Meanwhile on a side note, how many f@#king people in Broadbeach own BMW's? I couldnt get away from them.
Edited by Amaru
Spotted
Blue R32 GTS-T with 18/19" rims on old gympie rd at Lawnton this morning round 11am... You were turning off about 500m before Super cheap....
Had a few stickers on it.... Just noticed a 'Do-Luck' sticker on the rear right quarter...
Who ever you are your R32 is one of the niciest R32's i have ever seen... Very very clean and great choice of rims....
Also
1 minute later... A R33 S1 with no kit what so ever and with a S2 front end conversion... Very poorly done. S1 bonnet and head lights dont match the S2 fog lamp acemblies and you shoul never use fence wire to hold em on.... Very cheap....It also had a GTR rear wing, Car was painted poorly in midnight purple... Waved by got nothing... Note to you, just cause you think your cool by ignoring me means that i dont think you cool...
Im sad to say i spotted you are this is like the worst R33 i have ever seen.... I mean i have seen one pranged that look better...
Sorry...
I guess its so as i saw a horn r32 then a crap r33... Just the way it is....
Spotted
Also
Sorry...
maybe we should use cable ties to hold up gtr panels on ! sounds like a good idea... wat you think Col ? :(
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
