Spotted a red pearl 32 with big black rear wing....driving from canungra and then again a day later...heading from beaudesert to jimboomba direction. I hot looking sheila driving as well. Blonde...with glasses.....;) Cant member the plate was lookin at other things.
yer, twas me picking up wifey again
saw a heap of skylines doing the run over the bridge from west end
most waved!
it was a good day
Was that you behind me this morning on Fairfield road or whatever it is? (Up near boggo road)
i was in the White R32 with plates [sIR32]?
it was!
cool, i was wondering who you were
i barely even get to drive my car anymore these days :*(
wifey gets to do all the ks
Spotted a gunmetal 32 GTS-t this morning on the M1 heading outbound about 6.45am. Didn't get plates as I got caught behind some right lane dawdlers... I'm sure they are multiplying.
Also saw a red S2 R33 this morning on the way to work, couldn't see the plates from the inside the car :laugh:
Wife spotted SMR33 on her way home from work. Came home and asked me, "do we know anyone with the plates SMR33??" I said it was Karen's car and Andrea was astounded that she didn't remember that, as she always comments on the lovely colour of the car!
SPOTTED ERIN!!!!!!! On way home from work.....
Hehehe I cant believe u knew it was me, lol the poor car looks abit worse for wear at the moment, no side skirts, pods or front bar "NAKED STYLE"
Can always spot ur awespme car erin, looking good as always !!!
Hehehe was wondering what u was doin down that way :(
Good thing is GTR bar will be picked up tomoz morning, then get my newly accuired gtst sideskirts and rear pods fitted and it'll be all purdy again :)
Nice waving to ya, hehe on the brake flashes
cheers Pete (BOOSTA)
Awesome Dave...Marc would've been driving...hope he was behaving himself >_<
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
