Spotted a gunmetal or silver series 1 R33 with really foggy headlight lenses last night around 7-ish, chick driver, in Cannon Hill, following so closely that I couldn't see the headlights... tailgating at night in the rain is bad, mmkay?
haha, yeah, my horn is this little girly thing :O
everyone who hears it calls it the 'polite horn' as if its 'politely' asking the cars to get out of the way, or politely asking them to wake up and stop swerving into your lane....
i need a horn that says "GET DA FARK OUTTA DA WAY, BIATCH!!!"
spotted 4 seperate skylines on the way down the coast last night.... 3 of those were tryhards in R32 GTS-t's who wanted to race...
if you guys are on here, grow up....
why would i:
a) Risk losing my car for streetracing (Like one of you could possibly have done if you kept into it for a few more seconds, seeing as there was an undercover car on the side of the road up ahead)
b) Waste my petrol - i know i'm going to annihilate you, so why bother?
c) Risk damaging my car - air was cold, car was tuned in 30 degree heat, so would be running lean with the 20 degree air last night
d) Whats the point of streetracing anyway? Take it to a track, morons
oh, and there was also some chick in a riced up late model lancer who wanted a go :thumbsup:
I quite like the look of a (genuine) Evo.
Spotted a wine red R33 pulled over, bonnet up heading out of Ipswich, just after the Warrego Hwy merge at Riverview. Hope everything was ok - by the time we'd turned around and come past again help had already arrived so we didn't stop, too many cooks etc.
RIDE IT White 33 GTR tht was stolen and found spotted on Klumpp Rd at the lights...had a quick chat when the lights were red!
Also SMR33...spotted you driving past on riverside express way, bumpe to bumper traffic at 6pm.. I was on the phone at tht time and only saw you when u were ahead of me....:D
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
