1x white (very clean) r33 driving along coronation drive this morning at 6.40am.
1x burgandy (nope, wasn't SMR33) r33 driving onto coronation drive at toowong, 6.45am this morning.
1x burgandy r32 on stanley street at the lights in coorparoo as i was turning onto cavandish road at 7.10am this morning.
Getting more kw's hey Dave??? :)
Yes Karen, I am now the proud owner of 207rwkw!!!!
Due to a decent set of plugs, bloooooody cold temperature and a little tweeking of the fuel maps on the Haltech (love my Haltech)
All this without touching the turbo or fuel system!!!!
I wonder if Col will read this..........
And Benno!! Go the Haltech man!!!!
4 door R34 on SE Freeway this evening inbound, SAU stickers, headlight eyelid things, gave a thumbs up before all that TRAFFIC daaaamn!!!
tht was me!! :D I saw ur thumbs up and tried to catch up to u to return one but damn traffic! we should meet up sometime! nice 34! :)
i should try that shell extreme u talked about.
should give me another 2kw's you said?
spotted '93TME' R33 on the M1 at the hyperdome heading down the coast last night about 8:30...
on the way back i saw a gunmetal R32 with mexican plates, and also a darkish (black?) R33 (also mexican plates) at BP Coomera northbound around 1am
mexican plate??
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
