Spotted a beautiful silver Skyline, 672 HEY, southbound bruce highway. Must have been just after the gathering, unfortunately I couldnt make it. Cruised up beside me just south of Kallangur turn off and waved. Very nice car.
Spotted a Green? R32 broken down on Coronation drive this morning, young lady driving it...
i'm sorry i didn't stop, by the time i saw you, i was already past you with nowhere really to pull in, and the Traffic Response Unit was already there, i probably wouldn't have been much more help than he was...
Thanks Nate, lucky you didn't get too close a look, as it may go well but the paint is in bad condition (well... the bonnet and boot anyway.) Side on it looks alright!!
Spotted R32 GTS-t with purple and white number plates. Outside the Redcliffe cop shop...
Today at about 1pm
Hey col, spotted you today parked on newman road today about 1030. Sorry i didnt have time to stop for a chat mate, would have liked to!
Mick
Edited by 26GTS
Mick
Yeah i saw the blue r32... Nice looking car dude...
I thought at first it was bunta, i didnt realise who it was... Sorry...
I was on the phone trying to navigate to a certain tyre shop to get my new 265's on the back...
Arhhh i finally have rubber again... No stupid 205's...
Heh thats cool col, i didnt think u were in the car and only saw you at the last second. What tyre shop were you looking for??
Nice looking car too col, though everyone knows that :D
See you around again, Mick
spotted a dark r32 skyline, near northlakes, i was two cars behind you, when you decided to spin them up outa the intersection....
i weaved traffic but couldnt find you..
also spotted a black r32 on rothwell round about, ??? IZA
spotted on my way to work today - northbound on gateway
silver R33 gts-t with big ricey wing - rego 520 IXR
continuously weaving in & out of traffic - cut me off, nearly hitting my car :thumbsup:
such a shame not to have a bit more respect for a fellow skyline driver
Spotted 32-DET the other day on the way to work, between Coro Drive and the Riverside Expressway about 6.30 or so. Nice car, looks very tidy... might be time for new rear shocks though lol, every time it went over a bump the rear bounced for a good few seconds afterwards :P
Terry - yeah not sure it was us?? If it was, work has been pretty full on lately, that's my excuse and I'm sticking to it :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
