DBR33??? needs to learn some respect... not a wise move to give a fellow skyline owner the finger... i was in my daily neways.
I haven't given anyone the finger in months!! What the f@#$ are you talking about anyway???
(Respect is earned, not learned..... grow up and you may get some)
Could be Bryn. But that is why I am asking for details. I do tend to wave whilst maintaining my grip on the steering wheel, so it may look fairly lame but it is a wave at least. Most people driving a 'line don't even acknowledge another 'line ...... very sad....
my eye sight is not great, so a lot of times i can not see ppl's faces until it gets close. ppl may think im rude, but i do not intend to be.
also, it is very hard, ppl wave at you, when they are driving other cars, like daily runners......i have had a guy waved at me from a commodore, and i still do not know who that was......
How is another skyline owner meant to know who you are, if you are in your daily, which obviously is not a skyline?
If you supposedly got the finger you must have been doing something that warranted that action...I know Rhino personally (he's a great mate and a top bloke) and he just doesn't drive around giving the bird to all and sundry.
lbfalcon is right...keep the bitchiness to the whoretown thread
Spotted Blue R32 Skyline with wide body kit comming down what i believe is the pacific highway. Around the springwood logan holme area.
One word for that car, Nice. lol :blush:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
