spotted charcoal R32 GTS-t (with GTR bonnet & grill) number plates MNT41 this morning heading northbound on g'way - stuck in all that traffic like me (i was in my other car tho - red MR Lancer)
hey guys. i know im not from qld but i just got bak home from surfers paradise. random holiday and ended up right in da middle of schoolies :P
anyway a hellava lot of lines cruisin the highway and the main strip (esplanade? orchid st?)
few ones of note:
1. green 32 wit silver rims and a greddy sticker in the back quarter window on orchid st. very very nice car.
2. red 33 same place, the next day. gtr wing only caught a glimpse
3 orange 33 on esplanade
4 R33-SEXY a few mins lata. must say i havta agree wit the plates. not just talkin bout the car eitha :P
5 black 33 gtr on the g coast hwy on sunday
6 blue r32, black bonnet
7 burgundy 33 wit a big autosalon competitor sticker in tha back window.
8 orange r33 on the pacific fwy. at bout 5pm today. harlequin paint.
too many others to mention. these are the ones i can remember well tho. damn u guys have some nice cars!
Edited by Basti
hey guys. i know im not from qld but i just got bak home from surfers paradise. random holiday and ended up right in da middle of schoolies >_<
few ones of note:
4 R33-SEXY a few mins lata. must say i havta agree wit the plates. not just talkin bout the car eitha :/
im guessing the blue 32 with the black bonet was me ...dam there was so many skylines there to bad they all looked stock at least mine stands out from the crowd
i remember i used to see the car parked on uxbridge st when it was stock...now he bought the wing off Alex.
I think i prefer the stock one.
Saw a green R33 skyline at Geebung its a very different colour looks good.
spotted 83GTR on M1 today.
I spotted 83 GTR as well I think on tuesday afternoon. We infact spotted eachother on miles platting road near the logan road intersection and had a little chat. His car is pretty much the same as my GTR apart from the wheels.
i see this 33 everyday...
Spotted 17SOK 34 Gtt turning onto church Rd taigum at 5ish... got into it to sounds nice
Edited by Noy
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
