Spotted this morning on my way to work:
A black R32 sitting just past the gateway tolls. Belong to anyone here?
A red cefiro heading north just before the tolls
A silver S1 R33 getting inspected down at VI at work (RACQ)
I would have been the red cefiro.
(Currentlly in MT ISA)
Spotted 4 skylines today.
Firstlly 2 x R33's out side a mechanics workshop on the main street near Mcdonalds (The mechanic has a dyno dynamics dyno, I didnt catch the name of the shop) But one was a Beautiful Midnight Purple R33 GTR and the other was a bright yellow R33 GTS-T (Looked like mine to be honest).
I didnt get good photos of these cars as I was doing liek 80kph when I saw then and took a quick pic... :)
The other 2 I spotted out side Auto barn one parked there all day was a White R33 GTR with vinals (got a good photo of this one will post once I get back to Brissy and back to cable broad band) and the other was a Grey R33 series 1 with a front mount.
MT Isa is Skyline country... How many bloody hot cars are up here I saw the sweetest RX8 I ever seen today also and a V12 BMW. Might have something to do with the mining expo in town atm...
Spotted MRO33 at BP on Granard/Kessels Rd around 5.30 thisarvo. Looks hot!!!
Also a silver 32 with standard plates pulled up behind me at the BP as well.
Edited by Miss Niz
Here are the photos from yesterday...
Then this morning while having breakfast at Maccas I spotted a white HR31 GTS-X... Ummmm
and I also spotted a real red R33 Series 2 so I had to sms Karen straight away as I thought it was here at first as it had "tropical qld" number plates with the yellow on black and I was dead set it was Karen :P
Well im back in BNE now and glad to be here, MT Isa was a bit of fun but Id never live there.
If any of the MT Isa skyline owners see this and wanta catch up for a beer at the end of August send me a pm.
spotted the dude with the rx7 thats on here....last night around carindale. nice car buddy.....had a 7XT and some other numbers in the plates lol.
yeah that'd be me, I thought i recognised those plates, I was out looking for something to do lol, i havent hit boost in my car in a few weeks so i was on a mission to blow out some cobwebs :worship:
P.S. those lights at creek road take ages hence why i went up and around :P
I've been bottling up my spotteds hehe.
Spotted Benno (32SUM) on Logan Road near the car dealerships around 6pm last night. Liz and I were on foot.
Spotted 2LUKY (R34 GTT Sedan) at the Mitsubishi Dealership (must work there). And spotted Tiffany RB_TURBO_Bitch (a few times on logan rd)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
