Saw an R33 rego AAH33 and a yellow R33 in the Valley on Friday or Saturday night was that urs Col, didnt see the plates it looked like yours.
Nope not me sorry, My car unfortunatlly goes no where these days, just dont have the time to enjoy it much, but I do polish it allot these days and it lives in the garage with the bonnet up... Me and the boys sit around her and drink beer and knod allot... The garage is like my bar and the skyline is the centre piece... :thumbsup:
The body shop at Geebung who painted my car had photos of the completed job and they said they have painted 2 others (r33's) in the same colour in the past year. Its a hot colour, not many would think about it unless they saw the finished job...
I even saw this one in Mt. Isa, bad photo but thats what you get when trying to take pictures at 60kph... :thumbsup:
This was a spitting image of my car, even had the rear pods intact and the colour was an almost perfect match...
on monday, i spotted hackerx r34 in his garage while walking my dog :P also spotted a silver r34 sedan (possible hackerx again) at the set of lights near caltex and kippa-ring shops on anzac avenue. had sau on the side window. i was in my brothers white r33
spotted mrr34 driving through salisbury early in the morning a few times now
im often out walking when u drive past on lillian ave
You sure that is me mate cos i hardly go to Salisbury area at all? There is a silver 4dr R34 that has stickers all over the car and it looks like mine but without the widebody on it.
on monday, i spotted hackerx r34 in his garage while walking my dog >_< also spotted a silver r34 sedan (possible hackerx again) at the set of lights near caltex and kippa-ring shops on anzac avenue. had sau on the side window. i was in my brothers white r33
Yeah that would have been me. I think I remember the white r33.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
