Saw an R33 rego AAH33 and a yellow R33 in the Valley on Friday or Saturday night was that urs Col, didnt see the plates it looked like yours.
Nope not me sorry, My car unfortunatlly goes no where these days, just dont have the time to enjoy it much, but I do polish it allot these days and it lives in the garage with the bonnet up... Me and the boys sit around her and drink beer and knod allot... The garage is like my bar and the skyline is the centre piece... :thumbsup:
The body shop at Geebung who painted my car had photos of the completed job and they said they have painted 2 others (r33's) in the same colour in the past year. Its a hot colour, not many would think about it unless they saw the finished job...
I even saw this one in Mt. Isa, bad photo but thats what you get when trying to take pictures at 60kph... :thumbsup:
This was a spitting image of my car, even had the rear pods intact and the colour was an almost perfect match...
on monday, i spotted hackerx r34 in his garage while walking my dog :P also spotted a silver r34 sedan (possible hackerx again) at the set of lights near caltex and kippa-ring shops on anzac avenue. had sau on the side window. i was in my brothers white r33
spotted mrr34 driving through salisbury early in the morning a few times now
im often out walking when u drive past on lillian ave
You sure that is me mate cos i hardly go to Salisbury area at all? There is a silver 4dr R34 that has stickers all over the car and it looks like mine but without the widebody on it.
on monday, i spotted hackerx r34 in his garage while walking my dog >_< also spotted a silver r34 sedan (possible hackerx again) at the set of lights near caltex and kippa-ring shops on anzac avenue. had sau on the side window. i was in my brothers white r33
Yeah that would have been me. I think I remember the white r33.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
