Spotted Yellow R34 in the valley last night Plates were 05EXY i think.
last nite? ..... was it 53xyn?
Spotted Adam - Devils_advocate on M! nice to have a chat while driving :(
Edited by 53XYN
Saw purple 33 gtr with what looked like white te37s and ganador mirrors.
plates immacul8 i think i cant be sure i was doing 1km/hr going over a bastard of a train line at the time.
nice ride if ur on here man :D
sounds like HLUCN8 to me :(
was tail racing a Blue R32 through Burpengary couple saturday nights ago, you came up behind me and my very factory R32 at the lights just off the highway.
nice zhuast note dude, made my night as i was kinda falling alseep up till then.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
