spotted 580.KGP S1 R33 on Dawson road Mt Gravatt
Also Spotted RDY60 On M1 this morning first time i got a wave back from a skyline owner ( i was in my chaser )
I spotted that Chaser coming a mile away! I was a bit suprised you actually waved to me, now it all makes sense though lol.. Looks good btw!
yeah i recognised your car from last week fri's coffee meet .. arent you Tiffanys b/f? .. yeah i dont wave to other SAU members most give me a weird look guy in a toyota waving.. something must be wrong... lol
last weekend i saw a blue r33 gtr at maccas in gympie on friday night, had nsw or act plates.
then on either saturday arvo or sunday arvo i saw a r32 with nsw plates stopped outside melco mitre 10 in gympie. was a gts-t but had a fully sic gtr badge on it.
Gunmetal Grey R32 GTR. Plates - [***.HXY]. This morning on Coronation Dr, turning off the I.C.B.
Blue R33. Plates - [***.IXS]. Today in Kingsford Smith Drive.
Black R33. Plates - [***.HWN]. This afternoon on the Story Bridge (southbound).
Yeah I'm Tiff's b/f... My car was SO filthy at the meet last week lol... I didn't want to bring it out!
Spotted a wingless R33 maroon gts-t leaving qld raceway yesterday. Only noticed because the passenger decided to get out and have a piss beside the highway as a continuous stream of cars passed. Not a good look. 435OME or something like that?
Also a yellow R34 GTT on the gateway this arvo, moving slowly in the traffic.
so sad i havent seen my car up here yet, live in surfers and drive to hyperdome almost everyday so keep and eye out for me
Blue/grey 4door R33 gts-t Skyline badge on the back used to be pink but now ive painted the rear garnish and lights the same colour as the car-see pics
yes also note i have a drift toy a blue one lol
if u see me wave please i get lonley!
spotted a black r33, very nice looking car (male driver) at 3.45 this arvo on the bruce highway,we both took mooloolaba exit but i went towards uni and he continued on. anyone on here?
Edited by BLiNKsTaR
Saw N15MO (john) yesterday at Rocklea.. maybe on his way to the sunday market.. :rofl:
Flash at u but i guess u didn't notice since i was in my Blk Rav 4... :D
Nah not heading to the markets....heading towards a mates plc in Graceville
53XYN Posted Today, 09:58 AM
Spotted Glen yellow34 @ Mt Gravatt Tafe... parking lot and John (nismo) on M1 mate them wheels look hot as !..
Hah, spotted twice in one week..wats going on...stay away from my wheels! :domokun: You can have the white ones! :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
