spotted R34 GT-T with plates R34 GTT at slacks creek autobarn... waved no reply back :D....
Hmmm......I've got R34 GTT plates, but don't remember going to Slacks Creek Autobarn.....sorry dude! Were they QLD plates? what color was the car?
spotted heaps of liners today on my travels
White 33-ORG33 at arudal plaza with RID35 plate on the parcel shelf, obviously a chicks car with all the pink toys in it.
Blue 4door at Repco on brissy road-NSW plates
Blue 4door on gold coast highway in surfers-051 *** (two hot as chicks in the front!!!)
White 34 i flashed at and got weird looks-didnt get the plate.
A yellow 34 like vish's sitting outside "wheels that work" on ferry road-IM NOT were the plates (not what???)
Spotted Rohan today in his Brothers lux. First time we have actually spotted each other at the same time!
bahaha mad dude!!!
was that Chevelle playing?? :thumbsup:
Spotted a red 33 in garden city tonight...i think he was tryin to turn somewhere....
i was walking to me car.....
Spotted a R34 with number plates NISMO1 on the freeway around loganholme heading towards to city. All I can say is that car is sex on wheels. Gave a wave but I don't think they saw me waving.
tested the 'skyline owners wave' today going for a mock cruise through surfers (so my tatted mate can yell sleazey/wog/islander comments at people)....
spotted a couple of lines today in surfers - super hot 34GTR asian dude driving it - i let him in on the roundabout and he waved back
another white 33GTST but the tool didn't wave (he looked like one of those angry guys who's never been with a girl - you know the type)
oh and another white 33GTST with pink bits (:() on the interior and a blondey driving - think she gave a smile after seeing i was waving - too bad i had just got the third or 4th worst haircut ever today...
Spotted Noy this arvo near Bunnings Carseldine...
Had to high beam him to get his attention, lucky tho cause the cops were just down the road also another 500 metres...
So I was saying Hi to you, and in the process preventing all those around you from getting tickets... :(
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
