spotted R34 GT-T with plates R34 GTT at slacks creek autobarn... waved no reply back :D....
Hmmm......I've got R34 GTT plates, but don't remember going to Slacks Creek Autobarn.....sorry dude! Were they QLD plates? what color was the car?
spotted heaps of liners today on my travels
White 33-ORG33 at arudal plaza with RID35 plate on the parcel shelf, obviously a chicks car with all the pink toys in it.
Blue 4door at Repco on brissy road-NSW plates
Blue 4door on gold coast highway in surfers-051 *** (two hot as chicks in the front!!!)
White 34 i flashed at and got weird looks-didnt get the plate.
A yellow 34 like vish's sitting outside "wheels that work" on ferry road-IM NOT were the plates (not what???)
Spotted Rohan today in his Brothers lux. First time we have actually spotted each other at the same time!
bahaha mad dude!!!
was that Chevelle playing?? :thumbsup:
Spotted a red 33 in garden city tonight...i think he was tryin to turn somewhere....
i was walking to me car.....
Spotted a R34 with number plates NISMO1 on the freeway around loganholme heading towards to city. All I can say is that car is sex on wheels. Gave a wave but I don't think they saw me waving.
tested the 'skyline owners wave' today going for a mock cruise through surfers (so my tatted mate can yell sleazey/wog/islander comments at people)....
spotted a couple of lines today in surfers - super hot 34GTR asian dude driving it - i let him in on the roundabout and he waved back
another white 33GTST but the tool didn't wave (he looked like one of those angry guys who's never been with a girl - you know the type)
oh and another white 33GTST with pink bits (:() on the interior and a blondey driving - think she gave a smile after seeing i was waving - too bad i had just got the third or 4th worst haircut ever today...
Spotted Noy this arvo near Bunnings Carseldine...
Had to high beam him to get his attention, lucky tho cause the cops were just down the road also another 500 metres...
So I was saying Hi to you, and in the process preventing all those around you from getting tickets... :(
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
