Spotted yesterday afternoon a white r34 GTR plates ""SHOW OFF"" HEADing into kallangur.. i saw you seen me gawking haha
Hey mate,
Yeah that was me, was taking my two boys out for a "little spin" :rolleyes: I seem to get plenty more looks with the new plates... lol
Cheers Cam
Hey Cam, long time no see, whats doin?
Hey mate,
Yeah pretty good! Got the GTR back from APC after a couple of tweaks have been added :) It's been too long, I really missed being behind the wheel, the Evo is just not the same.....
How's about yourself??
Cheers Cam
spotted old mate ARE31 out near the train tracks before archy today. we both got stuck waiting for a train waited like 5mins at them lights.. was in the subbie
Hey mate i didn't even see you. Should have beeped or something.
Carl
Carl
u wer 3 or 4 cars behind talking to ur mrs and i was in the liberty lol.
next time :) but ill never take that road again.
u coming this wednesday for another practice.? :rofl:
Spotted jlnewton turning right off Gympie rd onto Hamilton rd heading towards the hospital...
I buzzed past toward the city and only spotted you ata the last second, cant forget those rims on a 4 door... Had to be you :P
Was at about 12ish maby 12:30
spotted rdy60 on the riverside express way this afternoon
You got stuck in traffic huh.. I went around :blush:
me too (yesterday)
Thought you missed me! car looks clean..
Spotted 2 x r32 on riverside expressway, both gunmetal... Then saw black GT-T come up and looked amazed to see us three driving along lol
Edited by readyGO
spotted good looking black r33 with a custom number plate that started with JPR or something like that.
it was at the big round about in maroochydore (the one that you take to get to noosa) at about 9:10pm took off really fast heading towards kunda park.
is that anyone on here?
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
