spotted a horny as r32 in the garage the other day, with the donk waiting to go in...
oh wait...thats mine. how could i forget it just looks soo sexy i guess.
spotted purple 33 today on creek road..
spotted a dark grey r33 coupe with exhaust and no tinted windows leaving the myers side of the plaza at about midday. bloke in it was wearing a business shirt and tie....... never seen it or the guy before.
was really quiet considering it looked like a 3'' system
Edited by r33cruiser
Spotted Dangerous Daveo's Cefiro in my front yard yesterday.....only came over to get the Krispy Kreme's off of me :banana:
Spotted Yvonnes new shiny extreamly tidy R34, in her driveway last nite while picking up my krispy kremes (4 boxes :) )
i used to spot you on my way to work have you changed routes?
I Spotted you man ! chucking a fulli hectix left run off logan road .. i was in my audi rs4 dont drive my 34 anymore :devil: dont worry i keep a eye out on ya :P
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
