Spotted a Silver R34 sliding into the gutter at pinkenba tonight, had an SAU sticker on the side...
He drove it away but the front end didn't look that well. :)
Hope there wasn't too much damage mate !! :(
I spotted the same silver 34 earlier when i did a lap through in my mates commodore wagon, must have been before he crashed...
If its the same car I thought he would have learnt after his attempted circlework a couple of saturdays ago which was lolworthy at best...
Are you sure you sw a 33 ?? coz i practically live there hehe and everytime i go im at the race and meets @ pacific habour near suva never seen a 33 only 32's
100% At Denarau Island, just out of Nadi... Dark Grey R33 Sedan :)
Looked in the rear view mirror and saw RAD33 exit onto Smith St behind me...
Noice car! Not that Im biased because its exactly the same as mine or anything :) ( besides the cool wing of course :O )
Edited by Snoop74
Spotted two Skyline's this evening near Garden City. Was behind then beside a white R34 (Nico47?) leaving Garden City past the cops standing by the tow trucks. Looked like a maroon coloured R32 had a close encounter with another car...didn't really take much notice of the other car, I was feeling rather sorry for the owner of the R32 :down:
Edited by N-DAWG
spotted Troy (Mushroom boi) in his 200SX 200DSX rego i was in dads pajero beeped at u a few times :P
Also a White R34 380KJM N/A with a bomex kit no wing lil indian dude driving on logan road
Spotted a nice 33 sedan pulling out onto brisbane rd near swifts sports club at booval. Top stuff.
Also some dori dori dipshit in a silvia fishtailing the car after coming out of the carlovers on the same corner. I thought you used chamois to dry the car off, not shake it dry.
Late model R34 GT-T Yellow with a GT-R Spoiler, was pulled over by the cops in a empty carpark at towoomba on Friday arvo.
Yellow R34 GT-T at Sunnybank lastnight.
Maroon Ser1 R33 GTS-T this arvo on Redland Bay Rd.
Edited by Owgasm
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
