Spotted a few on the weekend.
Silver 33 heading towards nerang on sunday (on hooker blvd/Nerang Broadbeach Rd)
Saw a white 33 in Coolangatta,
Also drove down some backstreets at coolangatta/tweed (just off Kenedy Drive) and saw a house that Had 2 skylines parked beside it.
also see a maroon 33 s2 with maroon rims around tweed/coolangatta alot.
ALSO - every day, i drive past a clean white 32 in Kingscliff, thats now for sale? :thumbsup:
Edited by Sagiedaks
Spotted a few lately
yesterday afternoon i spotted a silver r34 and a maroon r33 coupes near diddilibah.
and this morning i spotted a white r33 coupe passing saint andrews drive and a speed camera.
this isnt a nissan or a skylinebut well i spotted this Confused holden barina at inala ... had M3 badges on the rear too
I hope no ones missing badges off their M3...
Also Spotted Bunta and Anna on logan road myself and Adam were trying to think whos car it was sorry we were out of our brains ...
Spotted PFC33 black S1 on logan road , Black R32 OMY32
saw a few cars out at the drags on sat anyone here go??
white 33, white 33 with a black bonnet, grey 32 and a red 33
Just to jump off topic quickly, what times were you running Mort?
Messy was trying to get me out in my line but I had other plans.
And poor Messy, snapping his rockers... ouchie lol. atleast this is an excuse for him to start the headwork on the GTiR.
red clean, wingless 34 GTT sedan in Kippa Ring this afternoon...and later on a black GTT on the hornibrook bridge with kit and wheels...
same red sedan i posted pics of on the page before this? i spotted it today aswell :D
pretty shite ones actually first run was to embarrissing to mention :D but got 14.5, 14.6 and my mate got a 14.1 in her, best shes done is 13.9
mate took his GTiR out and killed it on the first run :) so far found 2 of the little arms that go to the valves pushed off and head gasket was kool
Just wondering if the dude with the Gunmetal Grey R32 from Darling Heights, Toowoomba is a member on here.
I was following behind you on my way home at about 9:20pm tonight, I came out sideways when following you into Stenner :)
Spotted turbs33 at 7-11 tonite :) also a noob in a yellow R34 coupe without a wing white 18" wheels who tried to race me in front of cops ... mate if your on here dont even bother its good that he got caught trying to drag..
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
