white R33 on wrecker road mansfield plates where LOV.17 thanks for the wave ! finally someone waves at a V35 ..
Also spotted a blonde chickie driving white R33 looked hot as with carbon bonnet on logan road ..
saw white 32 along archerfield airport road at around 11am... Had lots of pink and 2 girls in the font seats..
i think that might have been me?? pink plates etc... i think i had the only white and pink 32 there today.. i did spot a white 33 on archie airport road too!!
Spotted a Silver/Grey R33 along the M1 heading south just after Nerang. Had an SAU sticker on passenger side, number plates were something like 977-??? or 997-???. I feel weird looking over at strangers cars and waving, so i didn't :D SORRY ! :down:
Haha well then /wave... Drove past too quickly and couldnt wave!
The 32 looked really slick and clean - very nice. :cheers:
spotted white 33 at movie world today plates were "wkd33" very nice. if your on here mate from lookin at it u can get more than ur asking price i reckon. i parked out next to you away from the busy end figured id at least be safe next to another line.
Also was a blue 32 but didnt get plates.
i'm finding not many people wave at the v35
I don't see many V35's around so i'm not too good on spotting them. I've only ever seen two that i've recognised as an V35 but both times the car was parked and no one was in it. I saw both in North Lakes, might be the same car i saw both times.
spotted gts33 going up aerodrome rd with tze33 (TEZZA33?, TAZEE33??????) plates made no sense, who was acting a bit...hoonish
TZE33 (tease 33)
spotted red 31 plates GTS 51L...NSW plates
spotted blue 34 plates 57NGR (stinger im presuming) and a 33 cruising with him
Spotted a few skylines last night.
One 20uik purple 33 in browns plains at 6.50pm and one black?? 32 near kessels road at 8pm (918 fpm) I gave them a wave when I pulled up at the traffic lights! :( Nice car!
The 32 looked really slick and clean - very nice. :happy:
yeah same.. *waves back*
wow thanks :happy: i dont hear that very often :D
spotted a white 33 this morning at flinders view - no offence bud but it looked kinda dodge! :(
i didnt spot but Aliesha spotted 53YXN's v35 helping my poor sick 33 while i was at work and it sounded like you had fun especially with the alternator
and sorry for sending her to your door vish i only have your old number so couldn't call so PM it to me and i only sent her as i know you are only 1 min drive away from her place :P and anyone else who knows my car is kedron or further north
and at the next Coffee meet a Chai is on me
Edited by Damit
TZE33 (tease 33)
Thanks Kirk......... at least sum 1 gets it!
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
