I spot a White 33 with (I think) a 400R kit each morning at about 6am on Gold coast highway near Parkwood. Bright blue headlights very clean but always going the opposite way to me. Whoever owns it, very well done!
I'm too slow to way to other skyline drivers hahaha but so far all the ones I've seen have snobbed me.
Edited by Sparks
saw a silver GTR35 on aerodrome road in sunny coast, same as the one posted above at the mbah servo, SO NICE.
Also saw GTS R33 the otha night parked up, if you read this, i was the guy who pulled up with the maroon r32 cause my mate with that r34 was parked behind you talking to Tristan haha.
Edited by r32na
was in my mates R33 yesterday arvo going through strathpine on the way home from work and say 3 other skylines a white R33 with what i think was a Uras kit and female driver.....
Also a white R34 that was phat as Gt-t and kitted......
Also saw another white R33 up the road a bit.......
Lucky i didnt have my white 33 out other wise it mighta been a white fest... .Was to scare to wave though as they seem to hardcore for me =[
Pulled up beside a white 33 with 2 bikes on a boot rack about 6.30 am this morning around gympie & beams rd. You didnt say hi back, you had the too cool, straight ahead stare happening! lol lol
hahaha i see that heaps through there actually have never waved to him either.... we might actually see each other some times.... Im in either a white R33 though there... stock with shit rims are dark as tint.... and my mates Black R33 with only front lip S2 bar and no tint wat so ever lol.... depends on who is driving to which one it will be hahaha
yeah i saw you
also spotted "louda" i waved but got nothin back
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
