outside dan murphys to be excact, many skyliners around the holland park area?
Ooo yes.. that would have been yesterday :whistling: We were inside .. where were you?
Hmmm not too many around hp area, I see a silver r35 with standard plates around there sometimes though :thumbsup: I think he knows someone/lives around the bp down the road near the car wash
Chris Rogers in the AE van...
About 30 minutes ago h was cruising along southpine road just after linkfield road...
I pulled up along side at 70 and waved and waved and waved... He was in a world of his own, looked like he was listerning to phil collins... ;)
Anyways I hit it and flew past in the purple people eater...
that was you!!!
wondered who the hell that was. was listen to phil collins actually :dry: lay on the horn next time.
was that you rev head??
next time i see you ill start to blow u kisses and holding signs to have my babies ;)
hehe I doubt it, not unless you mistook my bike or my daily for a Skyline lol. The poor old 'line has barely moved in the last month, hooray for work consuming all of what would otherwise be my spare time!
I pulled up along side at 70 and waved and waved and waved... He was in a world of his own, looked like he was listerning to phil collins... :dry:
Sometimes you need to be a bit more patient with the elderly...
Spotted 83CKS in The Valley carpark again!! It's amazing I think your alarm was probably the only one that didn't go off when I drove past. Was gonna stop and leave a msg, but you might have thought me a stalker so I didn't!! Looked clean.
Peace.
Spotted numerous other skylines as well....no one waved....ghey.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
