Whoever works at Aspley McDonalds that owns that absolute abortion of a 33:
You need to get rid of that Austika from the side window. And no one is going to buy it with those horrible wheels on it. You may as well take your phone number and the 'for sale' sign off the back window.
lmao .....
If its maroon with no spoiler, different front wheels to back and a smashed up front bar then thats my neighbours across the road! dont know about that sticker but i think it has a southern cross one on one window?????
If its the same car ill cut him some slack on the front bar, he was backed into by a car with a towbar at the garage full tilt and busted it all up. The dude is refusing to pay so he is going to court or something and they told him he cant fix it until the case is heard or something.
lmao .....
That's the one! It's not maroon though, it's some kind of plum color... and it's HORRID! The wheels look like they came straight out of the display window at Bob Jane. Haven't seen the front of the car because it's always parked nose in. And yep, austika on one rear window.
Having read what you said, the front bar is probably the nicest part of the car :happy:
Edited by Isola
dunno now if its the same car lol lol
its that stock 33 colour, wine red or something but its not plum, maybe it was the light ...
It's not like my red, or Ravi's red. It's got more purple in it. I've seen it there in day and night and it's always looked purple.
Anyone seen my white r33 series 1 n/a with veilside kit and white rims and aftermarket bonnet???
Around Ipswich normally
hey mate i have im also round ipswich got me self a white 33 series 2 now with a aftermarket black bonnet if u seen it atround at all?>?
spotted a P plater R34 on saturday on bruce highway, open your eyes a little more and you would have spotted that highway patrol car sitting on the on ramp at the BP :happy:
oh, and dont speed through that section, notorius for highway cars :)
lol im looking at it now and its red/maroon ish .....
it goes like a rocket, he has had a whole heap of work done at bob romano i think he said. its on like 16 psi or something i cant remember the convo exactly.
hey no i havent seen it yet but will let you know if i do :happy:
btw spotted a gunmetal grey r34 around carol park area late afternoon
spotted a blue R34 entering the roundabout as I was leaving at Garden City tonight.
Spotted a white R34 Coupe in Mt Gravatt Village carpark
and two R33's on Logan Rd Mt Gravatt also tonight
The white 34 may have been me.... not sure tho
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
