silver 32 - 607cha, on the gateway thisarvo, running along in the same general area for most of the way
And a stagea that came out of the clem7 into the bad traffic on the south east freeway thisarvo. White '34gtt there to. Only needed to see a r33 to make the full set, though i had a bashed up '33 door in the back seat so that might count.
Today at about 5ish pm Dark Grey R32 GTR driving down on betty road towards boundry road. With right hand driver side door smashed. I was standing on trafic lights in Dark Grey/blackish R33 gtst on betty road.
R33 GTR on waller road at night i forgot your name lol (we met on southside meet once i came in my gf's Golf GTi & was asking questions for skyline) well my skyline is on road now :D and am loving it at the moment :D
Dude in a white 33 GT-R with what seems to be bronze te37 always driving down my street think he lives up from your folks defari
yeah i've seen him a few times going down to the gym at the end of my street - there's also a sweet black supra getting around there too.
lol why did your mate with the gtr change to those small rims?
Edited by defari
^^ yep.. could've sworn it had different rims a few months ago
Yeah mate, thats my GT-R,
I have a set of Apexi 17x9's for it with an awesome offset but i took them off to get completely fixed up, straighten polish etc on the gold coast and i put those blitz wheels on it in the mean time they are only 8's with a worse offset.
My other wheels are back on it now.
ahh sweet - didnt realise it was yours.
How much did you pay to get your rims fixed? I need to get mine done
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
