silver 32 - 607cha, on the gateway thisarvo, running along in the same general area for most of the way
And a stagea that came out of the clem7 into the bad traffic on the south east freeway thisarvo. White '34gtt there to. Only needed to see a r33 to make the full set, though i had a bashed up '33 door in the back seat so that might count.
Today at about 5ish pm Dark Grey R32 GTR driving down on betty road towards boundry road. With right hand driver side door smashed. I was standing on trafic lights in Dark Grey/blackish R33 gtst on betty road.
R33 GTR on waller road at night i forgot your name lol (we met on southside meet once i came in my gf's Golf GTi & was asking questions for skyline) well my skyline is on road now :D and am loving it at the moment :D
Dude in a white 33 GT-R with what seems to be bronze te37 always driving down my street think he lives up from your folks defari
yeah i've seen him a few times going down to the gym at the end of my street - there's also a sweet black supra getting around there too.
lol why did your mate with the gtr change to those small rims?
Edited by defari
^^ yep.. could've sworn it had different rims a few months ago
Yeah mate, thats my GT-R,
I have a set of Apexi 17x9's for it with an awesome offset but i took them off to get completely fixed up, straighten polish etc on the gold coast and i put those blitz wheels on it in the mean time they are only 8's with a worse offset.
My other wheels are back on it now.
ahh sweet - didnt realise it was yours.
How much did you pay to get your rims fixed? I need to get mine done
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
