saw a silver 34 4 door on blunder road at 6pm - I think the plates where xxx IPT or something like that... asian dude driving - did a skid at the lights then the car back fired and spun a bit.. ouch.. didnt sound healthy :(
Last Night 8:30pm
  • Silver R33 (GT-R maybe??) passed me on station rd loganlea
Morning 7:50am
  • Black R33 on kingston rd heading towards beenleigh - thumbs up and got a wave :action-smiley-069:
This afternoon 2:30-3:30
  • Teal coloured R33 series 1. Female driver looked stock as a block
  • Silver R32 female driver turning into harburg drive beenleigh
spotted a Dark Blue R33 with black rims, around 5pm on the side of the M1 near Coomera (Southbound) Looked like it was about to be put on a flatbed. :(
i spotted this aswell on my way home next day i spotted him on highway driving
it was just the fuel pump he said
:action-smiley-069:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
