Silver 34 drove past me AR34??? Something like this I think. Only saw for a split second (Driving opposite way)
At Forest Lake, the road outside Brodies @ 5pm this afternoon.
Hahaha, that was me dude. I was hanging out the window at you too! >.< Sif not notice. :whistling:
^^^ not the nicest feeling first thing in the morning.
what workshop ?
It was at efi, they charged me $99 because they couldn't get the front shaft out (took me less then 30 minutes yesterday and I didn't even have a jack). So now I'm waiting to get booked in at hi power motorsport.
Edited by lilcrash
haha what the F... only saw you for a second (mainly in the rear mirrow), was talking to Yennie :P I saw personal number plates so though, better check if its someone on here...
Spotted two S15's driving on the main road near option 1 garage, one white, the other canary yellow with QIK61 yellow and black plates at around 3pm.
When coming back from pinkenba just after I saw the s15s there was a white 3000gt/gto near option one aswell. Saw him again on moggil rd in kenmore about an hour later.
Edited by Silvia GTR
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
