welcome!
do you have a good alarm?
Thanks! Why do you ask?
I've looked into the forums and have been looking at getting a proper alarm/kill switch installed by one of the guys in brissy.
Can you suggest anything?
I ask because you are on the southside/ goldcoast and still own your car, if you'd like to keep it that way, go see Chris :) and enjoy
+'ing this up, have only heard/seen good things regarding Chris's work :)
Chris Rogers from Audio Express is the man you want to see.
Haha, I've already been in contact with him.. I'm planning to head up Friday/Saturday to get it looked at. Thanks for the info :)
Near me then, want me to add you to my list of people to inform is I go for an impromptu run over Mt Mee?
You should've pm'd that to him...
Welcome to the group mate! Car looks hawt. Just need to sort out the fourby stance. :P You should come to our weekly catchups. :)
Hey Guys,
This is my R34 GT-T fresh from Japan - 59,000km Completely stock with some wheels.
Im in Brisbane north side look forward to seeing a few of you guys around :)
Saw this car on ebay, aren't this one come with the weds sport rims?
Hey Guys,
Looks super nice! Welcome mate!
Added me yet?
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
