Whos is the black 34 with SAU stickers all over it parked quite often at the regatta? I just moved to the City and see it there all the time!
ok im convinced whoever this is actually works there or somewhere close by, 3x SAU stickers on each 1/4 window - im at the regatta at least once per week and its driving me insane lol usually parked on the road right at the exit between regatta hotel and 1st choice
Spotted on coronation drive today, yellow R34 with a f**kwit driver wearing high vis
Can't think of anyone who drives a yellow 34. If he was driving like a twit he probably wasn't ours.
Saw an older lady driving an athlete silver series 1 R34, turning left into Rode Rd, Chermside (from Gympie Rd) this arvo, around 4ish. Plates 34Neo.
saw an orange r33 in gympie today near coles. looked nice.
then i spotted a harlequin r33 gts-t with GTR badges front and rear. i face-palmed
I've seen the harlequin around a few times. Mostly broken down on the road side.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
