Spotted Dans 33 out at willowbank, he also cracked into the 11s good work bro :thumbsup:
A silver 34 with rust in the boot running 14s
A sliver 33 Gtr with a two speed run 10.7
Gambo was out (turbo ls1 r32) did a very very lazy 11.5 @ 127mph thing is a monster
Spotted an R31 on Friday heading towards Mount Warren Park and was near the Mitre 10 mega enter round about when I saw them. I was behind them in my blue r32. I swear they are a QLD member or at least a forum member as I knew the number plates but I am drawing a blank now and it finished in HR31. Also had the ERD sticker in the back window which made me miss ERD again.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
