I am yet to experience this slip thing that ppl have mentioned of the Noltec arms. I have ran them for around 15 months now. Have done two Dutton Rallys, about 6 track days, 3 or 4 motor khanas...and have literally got my car airborn twice over 2 undulations on the in field of the track when i slipped wide and onto the grass at about 190km/h :) The front camber is still spot on, so if anyone has actually experienced this slipping i suggest they were poorly installed :D
  • Replies 51
well my set up is the full syd kid set up
springs and shocks
sway bars
castor
camber
the springs and shocks settings/height are what syd kid reccomends in the thread (group buy)
I use R888's also. Last track day tyres were very hot on the contact patch
and still the max I can get is -1.5
I forget what the castor is, however, if I have max castor or as much as the adjustment allows, does it "reduce" the amount of camber I can dial in?
Im I a n00b at this?
Or should I just shut up and do alot more research? :)
Ah, that is good to know, I was advised against them by SK as he said they slip, I just blindly went with it...
Do the Noltec arms have the problem of the bushes flogging out?
yeah I agree with troy, what a load of codswallop. I've had mine for about a year. 2 or 3 track events including a nicely little backwards over a ripple strip at about 140kmh. no alignment change whatsoever.
I'm surprised people get so much camber out of the dogbone arms. I know what the problem was with mine. the ends touched each other inside the cuff. so yeah I could have cut them down and had heaps more adjustment, but the bearings in them didn't last long either. I would say I was running a lot of castor at the time which would have limited how much camber I was getting too. anyway I am much happier with the noltec arms. they are strong as can be, don't slip and have bushes and grease nipples installed. very good product.
wow.... this had turned into quite a handy thread.
alas... i'm a track newb, and really, won't be seeing much track time.
The reason i started this thread was to find out what other camber kit options i had besides the whiteline products which are +1/-1 camber. I've got possibly over -2 camber on the front right, and a few workshops don't know why, it's just the way it is. I've got near enough to '$500 a corner' tyres on my 18's and i don't want to chew them, so i need a product that can get me back to even tyre wear.
Judging from some of the responses in this thread, am i wrong to assume that 0 degree camber = even tyre wear? Is it actually not that logical?
If the whiteline kit can get me even tyre wear (what i'm concerned about more over performance) i'll get that, it just seemed like there wasn't enough change in degree's for that kit
cheers, and thanks for all the replies :thumbsup: A good source of info if i ever get into a bit more track work :P
daniel
For daily driving, the Whiteline camber bushes should be enough. 0deg camber will give you even wear if you only drive in a straight line, you need a bit of negative camber if you like corners, half the reason you have a skyline right?
Beer Baron or Roy: What are the Noltec arms like to adjust? Quick look says you just have to push the top of the wheel in/out... Or is there a simpler way?
I'm up for new upper arms soon as my dogbone ones are pretty rooted, so am considering the Noltec ones now :D
No issues with the bushes flogging out like stockers and Whiteline?
Edited by salad
yeah they are pretty easy to adjust. if you have small arms you can do it with wheel on even, but much easier with wheel off.
no problems with my bushes yet. give them a top up of grease before you whack them in. then do it whenever you get a chance. I think I did 1 pump per nozzle (4 nozzles obviously)
I reckon I'll be alright with 'em then, can adjust the dogbone ones with the wheel on. Taking the wheel on and off on a wheel alignment machine is too much of a pain in the arse for my liking ;)
Do they have any means of adjusting them easily like turning a nut/bolt? Or do you have to just physically push/pull to make it slide inside itself...
Anything along these lines?
My experience is that the whiteline adjustables lasted a week before the drivers side chewed out. No problems with the noltec thus far (~6 months). The Noltecs were installed by suspension experts who also did other work, the whitelines werent - no idea if that made a difference.
The -2 you have shouldnt be chewing out tyres, but -1 is more conservative. I suggest you go to a suspension specialist rather than a tyre shop for alignments tho - the competence and care level will probably be a lot higher.
I just ordered myself some Ikea Formula upper arms, after reading this i'm thinking I should have got the dogbone ones.
33 upper arms are a different shape. no dogbone shaped arms for 33 GTR. but i think the 33 design is a bit of an improvement anyway. you don't want the dog bone arms anyway. trust me! there are better options.
my experience is the noltec ones are horrendously overpriced and poorly made - the quality of the welding on the units that I ordered in (and promptly returned) was terrible. I run better welds than that, and I suck at welding.
The much cheaper dogbone arms gave me -3.5degrees and were very well made, even if they did come out of Taiwan. Adjustment is much easier - loosen the 2 locking rings and adjust via the turnbuckle, which also provides more accurate adjustments. Mine got full adjustment without touching inside the cuff. My car was street and track driven and the bearings didn't give me any problems. I'd buy them again for my next GTR without hesitation.
weird that we had such different experiences. you went from noltec ones to the dogbones, I tried the dogbones then went for the noltecs. I wont dispute the welding on the noltec arms wasn't exactly pretty or that their price is a little on the high side, but my first set of dogbone arms just didn't last long at all, and when removed one was slightly bent. the material used just didn't looks suitable and the bearings didn't last. the fact the two ends touched each other inside the cuff was another problem. The second set didn't do quite as bad but the bearings were noisy after only a fairly short period of use (i think 2 track days and about 500 or 600km). but they were a little better than the first set. but the noltecs gave me more adjustment, easy enough to adjust, and no bearing problems (well no bearings at all!).
each to their own I guess. :P
it is strange. mine were driven quite often on the street and a couple of track days. I had them in for about 6 months before I sold the car, so about 5,000km without any problem with the bearings.
I never used the Noltecs, sent them straight back as soon as I saw them. I wasn't prepared to pay top dollar for ordinary workmanship. but it certainly sounds like they work well enough.
I got a R32 GT-R. Any idea of adjusibily of the Ikea Formula arms?
I'm 90% sure ikeya don't make adjustable front R32 upper control arms. to be honest I didn't think the ikeya products were all that. they are ok, and fairly well prices but the cusco stuff is nicer.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
