V36 370gt
So M12 and sealant should be fine? NPT ” because that’s what I had and what I could get atm.
Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual, once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it also while you’re at it you should upgrade the transfer case with 10 friction plates
