For some reason, my car doesn't like going to fremantle. Whenever driving to freo, my HICAS light always comes on. It doesn't come on when coming back from fremantle, or travelling anywhere else for that matter. It only happens every single time I go there.
Guess she just doesn't like freo ;) ... what strange things do your cars do??
https://www.sau.com.au/forums/topic/192936-does-your-car-have-strange-quirks/
As soon as the warmer whether comes my aircon turns on randomly. Be driving down minding your own business and all of a sudden you hear "WOOOSHHH" and the aircon is on full speed. Only happens on hot days too. Not good when you are in the middle of Autotest and your trying to change gears and turn aircon off ;)
mine seems to veer into pub parking lots (it must think im an alco)
;) HAHAHAHAHAHAHA!!!! Nice :happy:
Mine is weird anywhere. . . . Aircon blows cold or hot air when it wants and hicas turns on and off when it wants. . . Scarey shit sometimes when the back end feels like its going side to side when i go quick. . ;)
i think they are supposed to lock - mine do it too...
isnt it a safety feature that was used..?
my drivers window goes down when it feels like it.
its embarassing when you are singing along to a song and your window just lowers by itself!
  • 1 month later...
My car farts at people occasionally.
My mans car does that to 2nd gear only, everytime without fail.
my car hates roe hwy, the stearing wheel and tyres start to shake/tremble...she remembers that terrible mazda ute that hurt her!!
  • 3 weeks later...
the hicas in my gtr would come on randomly
i would be driving along and would feel like tha back is steering out
was freakin me out as i had only had tha car for two weeks an coodn work out wat was doin' it did it bad 1nce
wen was doin a fair speed was very scary found out wat it was and unpluged tha stupid thing
Heheh I remember seeing that!
my 32 attracts sxy lookng woman and just lets them jump in,,,my g.f gets the shits, aint my fault,,,
:laughing-smiley-014:
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
