Happy Birthday Emsta :huh:
Hope you have a great day.....your such and old kent now
but i still love you
:yes:
ahahah thanx man...26 aint old man....still feel like im 21!
Happy birthday EMSTA!
thanx bud!
Happy birthday Matt
Make it a good one :)
thanx bud - where u been? havent seen u at monash much
Happy bday Matt, hope ya get ya car back soon as a bday pressie
thanx man - spoke to george today, abs sensors for the front wheels might be playing up...so hopefully wiht that and everything else fixed up - i will ahve the car at the end of hte week.
Happy birthday buddy!
I'll send some brownies in the mail
Have a good one!
:) look forward to the brownies!!
emssssssssstttttttttttaaaaaaaaaaaaaaaa........
Happy birthday fella, I got you a lotus for your special day
schweet! my very own lotus exige, pity i cant fit my lard arse into a matchbox car!
happy birthday akmal saleh....i mean emsta...
have a good one, and dont let that punk Mr J.Walker stand in your way
ahah thanx man - no idea who mr j walker is though
happy bday u raging queer
ahahaha thanx for starting a rumor on my bday u fawkin queer :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
