Hi Guys
I was talking to the software developer about the timing for the finished product this week (not confirmed yet, but latest should be September) and he mentioned that he is able show the fuel consumption in either km's/litre or litre's/100km's.
From what I see the norm is to talk about L/100km's. He is able to convert the fuel economy (or lack of it) screen to read this way.
I would think this is a great upgrade in the english conversion but I just need to know if anyone would not be happy with this change in showing the fuel usage?
Let me know your thoughts?
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-3916075
I don't mind in L/100KM as that's the convention used here in Australia.
In asian countries like Japan where the car come from, consumption is often measured in km/l to show how much km you get from each ltr you put in the tank... the mindset there is the bigger the number on screen, the better it is.
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-3916108
Hey Guys! I'm Aj, I'm new to these forums. I'm picking up my '03 350GT Coupe tomorrow! Just in from Japan. Really looking forward to it.
I'd like to say YES i am interested in the Software update from Jap to English.
Looking forward to chatting with u all in the future.
Cheers!
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-3923862
  • 4 weeks later...
Just going to bump this up because it is of interest to many...
Will there be any progress on the Sat Nav map side, as per the M35 info thread? If I understand it correctly, they can potentially do something for the DVD version but not the older CD version?
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-3982070
I theory, yes it can be done but there will be quite a few obsticles to be overcome before it would be available.
The english conversion of all the non GPS screens is due September and depending on the response to this first release the GPS conversion may be worked on as well.
It all comes down to the comercial decision of the time and effort v's the return in sales.
I am speaking on behalf of the guys in Russia who are doing the converting and this is what they have indicated so far.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-3982224
Hay Andy, so will the Russian converstion also convert the Japanese voice? Actually it would be a shame to take the mystery out of her LOL
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-4003404
I don't think we will loose her dulcet tones........ what are you doing that she talks to you? LOL.
The only time she talks to me is when i try to run out of fuel i the quest to fill up on Tuesday.
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-4003433
well,she dont like it when you open the door while driving-no brainer really.
up for the software conversion too!
https://www.sau.com.au/forums/topic/194126-software/page/5/#findComment-4003605
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
